Einbausatz originale Rückfahrkamera Duster, Lodgy, Dokker, Logan/Sandero II
Hello
Again sorry for english on german forum , but guess it will be easier for both me and you :D
My Lodgy was produced with original CD Radio. I've bought quite cheap MediaNav added GPS antenna and just replaced them without touching any wiring - just plug&play. Everything is working correct , navi , blutooth etc.
Unfortunately my MediaNav was previously upgraded to 4.0.5 and i'm unable to downgrade it - even full 2GB restore file is not working. Anyway i've decided to plug rear camera and found unofficial service equipped with CLIP ver > 146 to activate it. My only concern is if CLIP will be able to connect to MediaNav installed outside factory - is there any difference with wiring provided to RadioCD and MediaNav (are CAN lines available always or only when MediaNav is installed) ?
Regards
Marcin
Hello
Regards
Marcin
Connections are all the same. The CD Radio also has (the same) connections to the DIAG Port, like the Medianav.
To unlock the RVC with clip in a Radio that is not from your car just enter the VIN of the RADIO (car that it is coming from).
The Diagnostics of the car do not work with the Radio VIN, but you can reprogram the Radio :)
Thanks. Unortunately i don't know VIN of radio donor car. How can i reprogram (enter new VIN into) radio ?
Clip can not program a new vin into the radio.
You can start a normal diagnosis with the vin of your car. Then you can go to the (not properly responding) Radio and read the global Data from it like Partnumbers and the VIN. Write down the Vin of the Radio and start a new diagnostic session with the new written down VIN from Medianav.
Heute ist die Kamera angekommen. Jetzt fehlt nur noch das Auto :).
Heute habe ich dann das Auto abgeholt, Kamera war wie vereinbart montiert.
Ich kann den Kugelkopf der Anhängerkupplung in der Kamera sehen, der Blickwinkel ist also perfekt. Die rote Linie liegt 40 cm hinter der Stoßstange, wie es sein soll.
Allerdings habe ich auch die Fehlermeldung, wenn ich den Rückwärtsgang wieder heraus nehme, wie bei den anderen Media Nav Evolution auch (weiß jetzt nicht mehr, in welchem Thread das Thema war). Bleibt erstmal so. Mal schauen, ob ich später versuche, das korrigieren zu lassen.
Original Rückfahrkamera für Lodgy gestern eingebaut
Im Zusammenhang mit der fälligen Jahresinspektion hat mir mein Autohaus Müller in Freisen gestern eine Rückfahrkamera eingebaut.
Kosten: 142 € für die Kamera und 125 € Lohnkosten.
Die Fehlermeldung beim Herausnehmen des Rückwärtsganges erscheint nicht, der Bildschirm bleibt dunkel bis die Kupplung losgelassen wird, dann kehrt der Bildschirm zum Radio zurück.
Das Bild ist klar und deutlich, selbst bei Dunkelheit und trüben Wetter sind noch Konturen der Straße zu erkennen.
Wenn ich mir jetzt noch angewöhne, beim Rückwärtsfahren mehr nach vorn als nach hinten zu schauen, sollte das Problem der nicht besonders nach hinten bei Steigungen und Kuppen erledigt sein.
Und wie haben die das hin bekommen?
Intrepid: Keine Ahnung. Habe auch nicht nachgefragt, da mich zuvorderst das Ergebnis interessiert.
DerBaum: Ich bin zwar schon etwas älter, aber so schlecht sind meine Augen nicht, dass ich nicht erkennen kann, ob nach Herausnehmen des Rückwärtsganges eine Fehlermeldung oder nur ein schwarzer Bildschirm ohne Meldung erscheint.
Rückfahrcamera Nachrüsten beim MediaNav
hallo ist jemand zufällig aus dem Raum Hannover der mir helfen kann????möchte eine RFK nachrüsten aber dacia sagt no geht nicht hat vllt jemand eine Möglichkeit zum freischalten für mich???bin leider weiblich und null Ahnung
lg schleefi59
lg schleefi59
Es gibt für fast alle neuen Dacias einen Spezifischen Einbausatz VON DACIA sowie die zugehörige freischalt Anleitung VON DACIA. Jeder minimal befähigte Mechaniker / Autohaus sollte es damit hinbekommen. Und jeder DACIA/RENAULT Händler kann sie bestellen und auch einbauen. Wenn nicht, einen großen Bogen um dieses Autohaus machen, und ein anderes fähiges suchen.
na dann bin ich aufgeschmissen so einen großen bogen gibt's gar nicht beide Händler sagen es geht nicht
abdou
