Ressourcen-Icon
MediaNav (Evolution) MICOM Test Menü, Zugriffscodes, Einstellungen
Too bad I don't have any of that. Thought it was linked to the cruise control.
As long as your Media Display System hasn't any hardware on the layout you can't use these features. So it doesn't matter if your antenna is preinstalled for it or not cos the receiver hasn't a signal detecting unit. Only Media NAVI got the GPS system onboard.
BTW: You should update your SW to vers. 6.0.9.8.:D
Thank you for the answer.. Why I should update my Sw version? Is it better? or Am I getting any additional features?
Also I tried to open CP Wifi and AA Wifi , of course these aren't not working.. (I know someone tried that too)
In addition to that, Eco mode didn't work :) and Navi too. :) I will try another way to open navigation. Someone in my country (turkey) doing this type of improvement.. If i find a way to open any features i will share from here..
thank you all
thank you all
As long you don't have any hardware on the layout of the Media Display System board (e.g. WiFi chipset) nothing of your desire will work. Have fun to play with the MicomTexst Menu. It will always end in a dead end road.
It's still easier for a successfully feeling to buy a original Media NAVI from Dacia / Renault group in Turkey than play with the dead end settings in the MicomTest Menu. Kind regards.
Liebe wirklich geduldige alle hier,
ich hab mir dieses Forum von Anfang an durchgelesen und bewundere wirklich die Geduld und Freundlichkeit wie hier auf alle immer wiederkehrende Fragen 1000 mal geantwortet wird.
Ich habe versucht mein Farbschema von meinem Dacia Duster 3 zu ändern. Habe mir für meine Version 1.0.15.3 die datei heruntergeladen und habe mir gedacht es kann ja wirklich nicht so schwer sein die Druckpunkte zu erwischen. Nach gefühlten 100 mal versuchen komm ich leider nicht in dieses Menü.
Sind die Punkte für meine Version anders? Muss der Stick angesteckt sein um in das Menü zu kommen oder sollte es auch ohne aufgehen? Hie mal eine Foto von meinem Menü, vielleicht kann ja wer mit Bleistiftrückengröße das noch mal einzeichnen!? habs mit allen Fingern, auch mit dem Daumen versucht, geht einfach nicht und bin echt schon am verzweifeln! oder es geht bei mir nicht. Bin aus Österreich!
In dem Bild auf der Übersichtsseite wird es gut gezeigt wo man drücken muss. Ansonsten Mal bei YouTube schauen. Besser als hier dargestellt kann man es leider nicht erklären. Was willst du für ein Farbschema haben? Da du das alte NAV hast geht das neue Design ja dort nicht.
Dacia Duster 2 natürlich
Hast Du einen Duster II Phase 2? Oder einen älteren Duster? Welches Medienabspielgerät - genaue Bezeichnung - ist verbaut?
Dann sollte man Dir einfacher helfen können, auch ohne selbst Duster zu fahren. Ich hab nun mal nur einen Sandero III. Bisserl Technikinfo ist immer gut. Danke.
Das Renault Design sollte das Gerät haben?
Das ist so, wenn NBI aktiviert ist, hat COL keinen Effekt.
Hallo lajo
ich habe einen Dacia Jogger 2022 1.0 TCe 100 Eco-G und kann bei mir, NBI nur von OLD auf NEW wechseln, deaktivieren geht nicht, egal was ich auswähle es ändert nur das Dacia Logo beim Carplay, aber das Startlogo beim einschalten bleibt auf Dacia blau
hab von SW 6.0.9.6 .... auf die neue SW 6.0.9.8.1150_r3 umgestellt
die SW ....._r7 habe ich mit der anderen PW Zahlenkombi versucht, nur bringt es da > falsches Passwort
gibt es da noch einen anderen Trick ? um auch das Startlogo auf das Neue umzustellen
alles andere funktioniert soweit gut auch Appel CarPlay schaltet nun ohne Unterbrechung sofort zu,
ausser das Menü bzw. Anzeige Ökodrive fehlt, geht bei Benzin/LPG glaub eh nicht .
Hast du schon mal versucht auf Welcome 5 zu klicken bevor du mit Hard Reset abgeschlossen hast?
jo hab ich und habe nun auch den Trick dabei gefunden,
der Wechsel auf Welcom 5 darf nicht nur mit den > < Tasten links und rechts erfolgen sonder auch noch ein längerer Druck auf die dann angezeigte Welcome 5 Taste, bis sie kurz Rot leuchtet und dann Hard Reset ,
dann ändert es auch das Startlogo in Neu :)
Hej, Jubel und Dank an alle, auch ich habs geschafft das Display zu ändern
Hab mal mein Menü hier gepostet, was kann man denn noch interessantes umstellen??
Wenn ich mir so die Screenshots des Micom-Test Menüs ansehe:
Wo bekommt ihr eigentlich eure Langwellenempfangsmöglichkeit (LW Schaltfläche) her? Den habe ich nämlich nicht. Habe nur DAB, UKW und MW.
susimasa514
