HAB DIE LÖSUNG GEFUNDEN !!!!
DAS WAS EIN GESUCHE
, Lg Andrea
2.9- REMOTE ROOM TEMPERATURE SENSOR (OPTIONAL)
We mentioned in the “Theory” section that
the temperature sensor of the Webasto is located at the cold air intake of the heater. As a result, there is always a mismatch between the temperature obtained in the living space compared to the temperature selected on the MultiControl HD (the living space is warmer than selected). The solution is to install a
remote room temperature sensor in the living space (near the controller): once installed, the Webasto heater will use this sensor instead of the one in the cold air intake. Then the living space temperature will match with the one selected on the MultiControl HD! Here is how to install the remote room temperature sensor on the Webasto Air Top 2000 STC:
There is a resistor hidden somewhere in the wiring harness. The goal is to replace the resistor with the remote room temperature sensor instead:
Here is what the resistor looks like (after we trimmed it). Expect it to be hidden in the wiring harness under black tape, so you'll have to search for it:
We found the resistor near the Webasto heater itself. The remote room temperature sensor is 5 meters long, that was more than enough to route it towards the back of the van:
We installed the remote room temperature sensor near the MultiControl HD, and, since then, the temperature of our living space matches with the temperature we select on the MultiControl HD!
